Need help
Discussion in 'The Projects Forum' started by soo, Apr 18, 2010.
  1. soo
    Apr 14, 2010
    HI, i would like to build a project that consist a gas sensor to interface with JHD162A LCD and PIC16F876A.............may i get any suggestion what type of simulator can i use to test out the circuit.....
    IF JHD162A LCD just shown BLACK SQUARE in the display what are the possible problem...???
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    If all of the character locations are black squares then you need to look at your contrast control signal to make sure that it is in the proper voltage range.
    hgmjr
  3. soo
    Apr 14, 2010
    I using a trimmer to control the contrast.....actually is the 1st line shown the black square.... it cannot show my ADC output at the LCD screen......
    thx for your reply...............
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Your LCD control commands from the PIC are probably not correct.
    You may have tried to output binary data instead of converting it to ASCII first.
  5. AlexR
    Jan 16, 2008
    735
    54
    As hgmjr said it could be your contrast adjustment but if that does not help then check your LCD initialisation sequence.
    I think the JHD162A uses the 44780 controller chip in which case you can get the data sheet here.
    http://fab.cba.mit.edu/classes/MIT/863.05/classes/11_14/44780.pdf
    Follow the initialisation sequence on pages 45-46 to the letter making sure you have the required delays at the start of the sequence and between instructions as indicated.
