I've been cracking my head for hours, and I couldn't come up with a solution.
PIC I am using is PIC16F877A
Alright, I'm supposed to receive a value from the ADC and convert it to its appropriate value and output it to an LCD.
Attached is the code I did... but the problem is the values that come out are garbage and after that, I am getting "Hardware Stack Overflow". I tested it using PIC Simulator IDE.
Could someone help me debug the code?
Based on the Source Code, this is how I output the value:
And then the code goes back to the beginning to check for the ADC value again, and outputs a newer value when changed.
I know the code is long, but I sincerely hope you guys can help me out.
The problem starts here: OUTPUT CURRENT READING
- Add whatever value in the memory labelled First with b'00110000' in order to get the appropriate value.
- After that, I send out a '.', a dot signifying the next two values being decimal places.
- Then, I add whatever value in the memory labelled Second with b'00110000' in order to get the appropriate value.
- After that, I add whatever value in the memory labelled Third with b'00110000' in order to get the appropriate value.
