Need Help
Discussion in 'Homework Help' started by fahadatnet, Dec 24, 2005.
  1. fahadatnet
    Dec 22, 2004
    9
    Hi
    I am going to organize an event in my class for which I require few questions related to digital electronics. I will highly appreciate all you people if you help me finding new and twisting questions.
    The format of the event is like:
    The maximum time given to a team is 4-5 hours in which it has to design and implement 2 out of the 5 given questions. So anyone advicing me please keep these specipications in mind.
    The level of problems should be upto 2nd year engineering and use of microcontroller NOT is allowed.One can use simple ICs of logic gates,timers etc
    Please help me,I am also thinking about a few.
    Thanks in advance
    Bye
  2. Jimmy Lane
    Dec 27, 2005
    8
    What about utilizing the differing forms of ADC/DAC's???
    Flash ADC, Ramp ADC, Delta-Sigma(although that would probably get complicated!)
    You could do 4 or 8 bit converters, so as to save time and components
    Being completely honest, I'm a rank beginner in the field, and only a Freshman EE Student.....Professionally, I'm a recording engineer. My only real experience with digital electronics is in the audio field, where we use 24-bit systems with a Sampling Rate of 44,100Hz-96000Hz.....
  3. fahadatnet
    Dec 22, 2004
    9
    Hi
    No only basic ICs are to be used. No ADC,Flash memories can be used.
    Thanks for replying
    Bye
  4. mozikluv
    Jan 22, 2004
    1,437
    hi
    how about designing a resettable monostable timer using a 555. the timer can be reset even if it's in a middle of a count.
    moz
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    How about designing a digital lock, where the lock requires the input of a 3-digit sequence to open the lock. You could have a green LED indictaing that the input sequence was correct, and a red LED indicating that the input sequence was wrong.
    This may be more sophistocated than a few hours work, but it may be worth a consideration.
    Dave
