Need help
Discussion in 'Programmer's Corner' started by mickyunlimited, Aug 21, 2005.
  1. mickyunlimited
    May 5, 2005
    Dear All,
    Firstly I have two projects to make one in sql so let me tell abt it first. I am suppose to make a food supply database for airlines in SQL and I have no idea how to make it can some one help.
    Seondly I have to write a program in assembly language for unit conversion and bsaic calculator can someone help. Pls help me if you can
  2. nanobyte
    May 26, 2004
    118
    What assembly language are you working with for the unit converter/ calculator?
  3. mickyunlimited
    May 5, 2005
    Dear Nanobyte,
    It was my mistake that I didn't give complete description. I am suppose to write a program in 16 bit assembly language. Using AX, BX, CX, DX, SI, DI registers. Can you pls help ? The program should convert km to m, cm and mm and weight like kg to pound,ounce,gm etc. There is one thing more I have to display this in a video mode like I will load a picture and there will be a rectangular box on which these conversions should display. Can you also help me in displaying that ? Thanks in advance.
    Micky
