need help!!!
Discussion in 'The Projects Forum' started by aso, Jul 26, 2008.
  1. aso
    Jul 26, 2008
    Sir I'm a complete newbie about circuitry. I just want to use a cellphone battery BL-5C to a fetal Doppler that is using a 9 volts battery. Do you think it's possible?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    "need help!!!" is not a helpful topic message. The fact that you need input is obvious just by posting here.
    What do you mean by "a cellphone battery BL-5C to a fetal Doppler that is using a 9 volts battery"
    Is a fetal Doppler a very, very young Doppler? :confused:
    Please write in plain and clear English.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    According to Google, a "fetal doppler" is a gizmo for monitoring the heartbeat of a fetus.
    I very very strongly suggest any medical equipment NOT be modified in any way. If there is a problem with the gizmo, contact your medial provider immediately!!
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Nokia recently recalled 46 million of their BL-5C batteries. Seems that they like to overheat.
    It only supplies 3.7v.
    It would not only not work, but could be very dangerous to try it.
    I suggest you stick to the recommended batteries for the device.
