need help
Discussion in 'General Electronics Chat' started by the teacher, Mar 25, 2008.
  1. the teacher
    Mar 25, 2008
    5
    wich one of the following a.c values has the same heating effect as the equivalent d.c value
    A. effective value
    B. average value
    c. peak value
    d. peak-to-peak value
  2. sudharshan
    Member
    Mar 3, 2008
    11
    It is P=VAcos(Pi)
    Called as True power
  3. the teacher
    Mar 25, 2008
    5
    cheers for that answer
  4. recca02
    Apr 2, 2007
    1,211
    An Rms value has the same heating effect as the equivalent d.c value.
    http://www.kpsec.freeuk.com/acdc.htm
    search for RMS on the above site.
    Rms is a type of average value of AC calculated over one cycle.
    True power is something else..It is the active power provided to a load.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    I was looking for RMS, and didn't see it in the choice list. It varies acording to waveform, but for a sine wave it is 1/square root (2). 120VAC is an RMS value, the peak to peak value would be 120 VAC * Square root(2) * 2, or 336V P-P. The 2 is in the equation because without it we would be talking peak voltage, or one side of the sine wave only.
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Last time I checked, cos(pi) was negative one... Effective (aka RMS) value is peak*sqrt(2), as has already been noted.
  7. surbhi
    Mar 26, 2008
    5
    A Root Mean Square (RMS) voltage gives the same heating effect as a DC voltage of the same value.
  8. JoeJester
    Apr 26, 2005
    3,403
    1,229
    RMS = effective.
    After all,
