Need help with truth tables
abanj
Joined Mar 11, 2012
draw a truth-table for conversion of binary variable abc ranging from (ooo-111) to gracode xyz. hence use the product of N distinct literals where each literal occurs exactly once to drive the logic expression.
then use the expression to draw a logic circuit. some body please help
Wendy
Joined Mar 24, 2008
23,415
Welcome to AAC!
A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
This was split from Electronics AC/DC + Logic Cheat Sheets (Final Edition)
Please note, the cheat sheets are a resource, not a thread to request help. If you had a cheat sheet to contribute it would be a good place to offer it. It is not meant to be used as you have tried.
