Need help with trig identities problem
Discussion in 'Homework Help' started by strantor, Feb 27, 2013.
  1. strantor
    Thread Starter AAC Fanatic!
    Oct 3, 2010
    4,302
    1,989
    PLZ NEED HLP URGENT.
    I kid, I kid. I had this question in my homework last week and tried probably 5 times and then wrote it off as a loss. Now it's come back around to abuse me on a take home quiz. So I've just now tried it another 7 or 8 times and about to pull my hair out. I'm supposed to pick either the left side or the right side, and using trig identities, work through the problem until the 2 sides are the same. I've tried both side and gotten nowhere.
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    Your first line is ok.
    Don't expand the denominator.
    Expand the nominator, as you have done on the second line.
    Your result of 2 + 2sin is correct.
    The identity should be obvious from there.
    strantor likes this.
  3. MrChips
    Oct 2, 2009
    12,636
    3,455
    Note that this identity is not true under two conditions.
  4. amilton542
    Nov 13, 2010
    494
    64
     \frac{cos(x)}{1 + sin(x)} + \frac{1 + sin(x)}{cos{x}} =
     \frac{cos^2(x) + [1 + sin(x)]^2}{[cos(x)][1 + sin(x)]} =
     \frac{[cos^2(x) + sin^2(x)] + [1 + 2sin(x)]}{[cos(x)][1 + sin(x)]} =
     \frac{2 + 2sin(x)}{[cos(x)][1 + sin(x)]} =
     \frac{(2)(1 + sin(x))}{[cos(x)][1 + sin(x)]} = 2sec(x)
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    DOH! So simple. Thank you MrChips!
    Edit: and amilton too!
  6. amilton542
    Nov 13, 2010
    494
    64
