Need help with triac circuit
Discussion in 'General Electronics Chat' started by logans_daddy, Nov 20, 2008.
  1. logans_daddy
    Nov 20, 2008
    Hi all
    Let me start by saying that im not an electronics guy. I can follow some of this stuff but most of it is above me. I was hoping someone can help me out with a schematic to build a triac switched circuit for a level sensor application. I need to know how to stepdown the voltage so that im not sending 110VAC through my float switch. In short, i want to have a small hobby size AC water pump come on when the switch is closed using a very low voltage going through the switch.
  2. mik3
    Feb 4, 2008
    4,846
    63
    If you are not familiar with electronics its better to use a low voltage coil relay to control the pump. Use a transformer to step the voltage down to 12 or 24 VAC depending on the voltage rating of the relay coil and use a switch to activate the relay with the stepped down voltage.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Or even a wall transformer to drop the output to 5 volts DC and use a relay with a 5 volt coil.
