need help with this circuit
Discussion in 'The Projects Forum' started by KMK, May 25, 2010.
  1. KMK
    Thread Starter Active Member
    Feb 11, 2010
    68
    i have designed this simple circuit using 555 timer & 4011 nana gate chip. the circuit is designed to use IR remote sensors to switch the output of the 555 bistable function so the output can go high & low onan IR pulse.
    however the problem is that the out put of 555 remains in an on position. Normally, it flashes when it recives an IR pulse. sometimes it goes to low outpot (max upto abt 2 min) & then automatically switches to high. also the light from other sources in the house seems to be affecting this behaviour. can any pls help me with this so that it work properly??
    here is the circuit diagram. & the Vcc is 3V, not 4.5 as mentioned in the diagram.
    thanks.
    P.S. this is designed on a bread board.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Can you post a schematic?
    That will make things more than the many words.
    Bertus
  3. KMK
    Feb 11, 2010
    68
    unable to upload the image.possibly can email it.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You can upload an image using the manage attachments button:
    Bertus
  5. KMK
    Feb 11, 2010
    68
    let me try. the problem possibly is the size is 380 Kb
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Are you trying to upload a .bmp?
    Those are very large.
    Try to save it as .png.
    That is a lossless compression method.
    Bertus
  7. KMK
    Feb 11, 2010
    68
    isn't alowing me to upload the file to an album eiher. directly gives me 'IE cannot display this page' error for both the uploads. & now I was trying a 130 Kb file. possible issue with IE or the antivirus software.
  8. KMK
    Feb 11, 2010
    68
    also a i have said, the IR sensors seem to be sensitive to visible light, as the circuit seems to work when there is light in the room, but changes to high auto high output once the lights are turned off.can you explain me that?
  9. KMK
    Feb 11, 2010
    68
    no luck in uploading picture.
  10. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is the filename's extension?
    You could always use a .zip utility, and then upload it.
  12. KMK
    Feb 11, 2010
    68
    have tried that even. that too dosent work. any other suggessions???
  13. KMK
    Feb 11, 2010
    68
    even a zip file dosent work
  14. KMK
    Feb 11, 2010
    68
    hi Bertus, I've finally got the picture
  15. KMK
    Feb 11, 2010
    68
    now can any one help me figure the solution out??
  16. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Nothing about the "IR Remote Sensor" other than it's somehow wired in there?
    Do you have a datasheet for the sensor? Manufacturer's part number?
    Are those both IR sensors on the left?
    It looks like you have the outputs of NAND gates wired together with the outputs of the IR receivers. This is a no-no. You can only wire outputs together if they are both open-collector (or open drain) and current is supplied by another part of the circuit.
  17. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Here is the functional diagram of the NE555:
    Pin 6 of the NE555 is undefined at the moment.
    Try it with pin 6 tied to ground.
    Bertus
  18. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Bertus,
    Our O.P. DOES have pin 6 of the 555 connected. Unfortunately, it has the output of a NAND gate as well as the output of an IR sensor connected to it. Two outputs connected together = trouble.
    Same thing with pin 2 of the 555; a NAND output and an IR output are connected together to pin 2. More trouble.
    Since there is no information on the IR sensors posted, it will be difficult to suggest a course of corrective action.
    Pins 4 and 5 of the 555 are not connected, but it should still function that way.
  19. KMK
    Feb 11, 2010
    68
    actually, the ping 6 is grounded, forgot to update that in the diagram. also there is no part # as such for the ir sensors, nothing mentioned on them. also the idea is to use the gates to turn off the dupply to one of the sensors when the other is active & the out put of the sensors is given to pins 2 & 4 to ses or reset the 555. also as is said earlier, it seems to be working fine, when there is light in room. as soon as the light is turned off, it goes to kind of auto on position. also if the sensors as disconnected & used one at a time, they seem to perform thei function, ie. one will turn the output on & the other will turn of. but when both are connected, the output goes low for some time & the comes high automatically. what could be the reason for this?
  20. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can supply no information for the IR sensors, so you want for us to make guesses?
