Need help with this circuit
Discussion in 'The Projects Forum' started by barrage, Nov 7, 2009.
  1. barrage
    Nov 7, 2009
    Hi, need help with this thermostat circuit. I'm using a lm311n to try to activate the relay, but seem to have an output voltage reguardless of the voltage diff at the inputs. The circuit is below, except inputs at pin 2&3 are swapped, 500k hysteresis still at pin 2. Any ideas what might be going on? Thanks
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Are you certain that the 1N4148 is installed with the cathode towards +V?
    What is your +V?
    What is the voltage rating of the relay coil, and what is it's resistance?
  3. barrage
    Nov 7, 2009
    Supply voltage is ~12V. The output at pin 7 ranges from ~9.5-12V. I might have the cathode backwards - I had trouble deciphering which end was which on these diodes... And here's the info on the relay.10 AMP PC RELAYContact Res.: 50mΩ max.
    Operate Time: 10ms max.
    Release Time: 4ms max.
    Insulation Res.: 100MΩ min.
    Mechanical Life: 100M cycles
    Electrical Life: 100K cycles
    Resistive Load: 10A@28VDC or 10A@125VAC
    Inductive Load: 3A@28VDC or 3A@125VAC[/B][IMG]http://www.mode-elec.com/main/getpicture.php?id=536&type=img_med2[/IMG]Circuitry SPDTOper. Voltage 12VDCCoil Resistance 400Ω
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, 12v/400 Ohms = 30mA. That's well within the sink current limit of an LM311.
    However, if you're using an LM339 comparator instead, you'll have problems - an LM339 can only sink up to about 6-8mA current.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Try disconnecting pins 5 and 6 on your 311. It may be causing too much current in the inputs.
  6. barrage
    Nov 7, 2009
    Got it. Rookie mistake on the diode. Tested the diode, had it flipped around.
    Thanks SgtWookie.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Glad you figured it out. :)
    Just remember that the end with the band on it is the cathode.
