Need help with this circuit
Discussion in 'Homework Help' started by kirit, Oct 8, 2008.
  1. kirit
    Thread Starter Active Member
    Sep 9, 2008
    35
    Hi, need help determining v1,v2,v3,v4. My answer isnt the same as another student and i need to know who is right.
    here is the circuit:
    Ok, this is what I get:
    v1=27.0248V (node A)
    v2=22.0248V (node B)
    v3=19.8347V (node D)
    v4=15.0000V (node C)
    The other person is getting answer close but not exactly the same.
    Here is what equations im getting:
    Supernode AB: (Vb-Vc)/20+(Va-Vd)/8=1.25 simplifies to 7Vb -5Vd=55
    Node D: Vd/40 + (Vd-Vc)/12 + (Vd-Va)/8=0 simplifies to 28Vd - 15Vb = 225
    Knowns:
    Va-Vb=5
    Vc=15
    Any help? Thanks in advance.
  2. hitmen
    Sep 21, 2008
    159
    My answer is slightly different
    Va = 2710/121 = 22.36969
    Vb= Va +5
    Vc= 2100/121 = 17.355
    Vd = 15 (obvious)
    Do check my answers I could be wrong.
    Do reply if I got it wrong.
  3. kirit
    Sep 9, 2008
    35
    looks like your getting answers closer (almost exactly) to his than mine. Looking at my equation can you spot my error in thinking/execution?
  4. hitmen
    Sep 21, 2008
    159
    I think there is something wrong with your simplification. I can't pinpoint where it is.
    But there should be an error in 7Vb -5Vd=55 & 28Vd - 15Vb = 225
  5. hitmen
    Sep 21, 2008
    159
    I made 1 error Va should have a negative sign. I got the same results using mesh analysis also.
  6. kirit
    Sep 9, 2008
    35
    First thanks for the help. :)
    Plugging either the simplified form or the original equations into my ti89 still gets me the same answers. So it looks like the original equations are wrong.
  7. kirit
    Sep 9, 2008
    35
    Frack!Frack!Frack!
    Ok, re-did the problem:
    I didnt get my known right. It should have been Vb-Va=5. Seems fixing that and then solving the equations based on Va got me the right numbers. :) Or at least numbers that agree with you and the other student.
