Need Help with Thermal printed-results scanner
Discussion in 'The Projects Forum' started by Billy Michale Usana, Dec 29, 2014.
  1. Billy Michale Usana
    Dec 29, 2014
    Hello. I'm a new guy here. Thanks in advance for those who could help me.
    My groupmates and I are having a design project which has the title "A Design to produce digital copy of electrocardiogram thermal printout"
    The plan is, to design a way to retrieve drawn out results from a thermal paper, specifically the ECG results, then turn it into a digital data, or at most, a signal that could be processed (pretty much like from track recordings like audacity, garageband)
    certain things should be considered like:
    1.) detection of grid (measurement of the wave itself)
    2.) Detection of plot
    we plan to use a hand scanner, or scanner to scan in the results
    the design is described basically this way:
    What algorithm could we do to retrieve the scanned results and plot out a signal
  2. frpr666
    Feb 2, 2010
    37
    6
    I think you will need computer power for image processing. There are open libraries that can do that work for you. Try to ask at processing forum. https://processing.org/
