Need help with the parameters for low power AM transmitter
khadeejabaqui
Joined Jan 25, 2016
9
We are able to design the following project for middle school Science fair.
http://www.sciencebuddies.org/science-fair-projects/project_ideas/Elec_p024.shtml#procedure
We used only 1Mhz oscillator.We are not using 1.20MHz Oscillator.We do not have Oscilloscope.We are able to measure longer distances of output signal with longer antenna wires.
The question is
what other parameters of out put signal can we measure?
If we send constant input signal( for example 440Hz input signal),is it reasonable to show that same output signal frequency is obtained using any frequency app?
If we decrease the input voltage ,will the output decrease?What should be the effect?
Where exactly carrier signal is given?transformer or Oscilloscope.
Can anyone please explain the circuits (including changes in amplitude voltage and frequency of the signal)?
khadeejabaqui
Joined Jan 25, 2016
9
The question is
khadeejabaqui
Joined Jan 25, 2016
9
It was the previous picture.I am done with experiment part.My only question is what parameters of output signal should I show for the Science fair as I have no Oscilloscope.
ronv
Joined Nov 12, 2008
3,770
Draw a picture of the output and then show how it would look going to the headphones of a crystal set.
