Need help with Soldering iron
Discussion in 'General Electronics Chat' started by SwMuBl, Dec 10, 2013.
  1. SwMuBl
    Dec 10, 2013
    I'm looking for an adjustable soldering station and iron that has the shortest tip possible. I've been researching for days and the Pace TD-100 is the shortest I can find.
    Even after finding that I think I would like shorter.
    The distance I am referring to is where the grip ends and the stalk of the heating element/tip begin to the end of the tip.
    Thanks for all the help.
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    May not be relevant but I've been very happy with my cheapo soldering station. You can get it on sale for something like $12. I don't think the tip holder is especially short, but at least you can get a range of tips for it. I use the finest tip for nearly 100% of my usage.
    SwMuBl likes this.
  3. SwMuBl
    Dec 10, 2013
    Good idea, and seems like a cheap route. How does the actual iron hold up while changing tips and such? Is it pretty secure and sturdy?
    I've been using the X-Tronic 4010 but I use the soldering iron for 4+ hours a day so I wouldn't mind something of good quality or on the more expensive side. The X-Tronic is probably good for casual use but I keep breaking the actual irons because I have to change tips quite frequently...
  4. Metalmann
    Dec 8, 2012
    700
    223
    That would be a great project for these guys.....design a tip no longer than 2 inches. That would come in handy sometimes.:cool:
  5. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    Or just use a metcal iron ...
    SwMuBl likes this.
  6. SwMuBl
    Dec 10, 2013
    Looks like the Metcal is a great option, thanks. Do you know if the tips interchange easily and where to get them.
  7. mcgyvr
    Oct 15, 2009
    4,793
    976
    I wonder why you need a short tip?
    "vaporizer" maybe?
    I just can't think of a proper situation where the shortness of the tip would ever be a benefit.. Longer sure but shorter?
  8. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    More control .. better comfort thinner and sleeker design ... less thermal mass to heat
    Metalmann likes this.
  9. mcgyvr
    Oct 15, 2009
    4,793
    976
    besides "sales/marketing" garbage..
    less thermal mass..ok maybe but I don't think that any of those are the reasons the OP is asking this question in the first place..
    He mentioned having to replace the tips all the time.. and thats far more related to proper care than anything else..
    We've got a bunch of Hakko FX-888 models around here.. They are plenty "short"
  10. Metalmann
    Dec 8, 2012
    700
    223
    Back when I was TIG welding, I always thought that the 1/8" Thoriated Tungsten electrode, would make a dandy soldering tip.......but how to heat it consistently.?:confused:
    And, to make it adjustable?
  11. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    Lets try this...
    Take a pencil and write your name with your fingers 6" away from the tip and now try it 3" away and see what happens ..Have you ever take a look at Metcal or JBC irons ??? The handle is very small and thin and the element is really close to the grip...
    Have you ever use a short iron before ??? I would love a Fx-888 but I use a busted up hakko 939 that works good ..
  12. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    That's a neat Idea now build it lol...:D
  13. alfacliff
    Dec 13, 2013
    2,449
    428
    if variable heat is all your looking for, use a light dimmer, the kind used on the wall of your house to dim lights. they are rated for 500 to 1000 watts. put it in a small box with a receptical for your favorite iron, and off you go. most solder stations without temprature readouts are basicly just this.
    cliff
  14. SwMuBl
    Dec 10, 2013
    More control is precisely why. Like I mentioned, I don't use a soldering iron for soldering. I have to replace tips a lot because of constantly putting pressure on them. Also with the longer tips, I tweak my hand in an uncomfortable position. With a shorter tip I would be able to use a different method.
