hello everyone, i just learned about this site and wanted to see if i can get any help about my current project.
i recently made an opamp with cadence for a project. i have used the basic topology (two-stage = differential amplifier + common source - attached with a current generator). now for my questions:
1) i was able to meet all the specs except for the slew rate. i am not planning to work on it any further though, i did everything i can but the layout simulations doesn't give me the slew rate i want although the schematic simulations does. My question is, how bad it is for an op-amp to have low slew rate? How it effects the usage?
2) my most annoying problem, every exaple i saw and every text i read says that the phase margin of the opamp stops at -180ô, however mine goes beyond that up to -350s. is this a problem or can i neglect this?
3) there is a huge power consumption difference between my schematic and layout simulations that i can't explain. only difference between is that in schematic, the R next to compansation capacitor is 20 kohm and the same R in layout is 30 kohm. schematic simulation displays a power consumption of 400mW whereareas, layout simulation displays 100mW confused What might be the reason for that? (layout extraction for simulation is C_only btw)
thanks to all who bothered to read =)
