Need help with sallen key bandpass filter
Discussion in 'Homework Help' started by alialiali, Mar 12, 2009.
  1. alialiali
    Dec 12, 2008
    26
    Hi every one
    I'm working on bandpass secound order filter and I have to have band pass between 23k and 53k using sallen key filters whaen I use the formola to dsign my high pass which should gave me 23k fc its working and I used the folwing calculation
    R1 = mR, R2= R, C1=C , C2=nc FSF = 1 from the table
    FSF * fc = 1/ 2pi RC squrt mn
    m= 0.229 from the table
    n= 3.3 from the table
    I'm looking for LP for 53k
    1*23k=1 / 2pi * (C=0.01u from th table) * (R which we need 2 find) * squrt 0.229*3.3
    R = 1 / 2pi * (C=0.01u ) * (23k) * squrt 0.229*3.3 = 707 ohms
    Since R = R2 so my R2 value is 707 ohms
    R1 = R*m = 0.229 * 707 = 161.9 = 162 ohms
    C1 = C which is 0.01u so the value of my C1 is 0.01u
    C2 = n * C which is 3.3 * 0.01u = 33n
    so my C2= 33n
    and my LP filter which should gave me the fc=53k as
    1*53k=1 / 2pi * (C=0.01u from th table) * (R which we need 2 find) * squrt 0.229*3.3
    R = 1 / 2pi * (C=0.01u ) * (53k) * squrt 0.229*3.3 = 345
    Since R = R2 so my R2 value is 345 ohms
    R1 = R*m = 0.229 * 345 = 79.005 = 80 ohms
    so my C2= 33n
    the main problem when I contact the output from my HP to the input of my LP filter the over all fc is not maching the fcs I looking for
    can any one advice me how to conact the two filters together this can be using athered filter but my quation is do I need to change the holl calcultion and how?
    many thanks
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Your resistors have a very low value.
    What happens when you divide the capacitors by 10 and multiply the resistors by 10 ?
    The frequency will be the same but the impedance will be changed.
    Greetings,
    Bertus
  3. alialiali
    Dec 12, 2008
    26
    I dont know can you explin bit more please
  4. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    What I am trying to say is : recalculate the filters with capacitors of 1 nF and n* 1nF in stead of 10 nF and n* 10nF.
    Greetings,
    Bertus
  5. alialiali
    Dec 12, 2008
    26
    Ok I did that divide the capacitors by 10 and multiply the resistors by 10 I can see some difrernt but the problem now is I am getting 57.71kHz for the LP which it should be 53kHz and the HP= 20.84kHz which should be = 23kHz
    please can you help me more
  6. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    What kind of filter are you making ?
    Where is the table you are talking about ?
    Most sallen-key filters I know have equal resistors for the low pass and equal capacitors for the high pass.
    Greetings,
    Bertus
  7. alialiali
    Dec 12, 2008
    26
    Many thanks for your king reply
    I enclod copy of the table so you can have look and gave me some advice
    Table 1. Butterworth Filter Table
    FILTER FILTER
    ORDER
    Stage 2
    FSF Q
    1.000 0.7071
    1.000 1.0000 there is full table in the picture below
  8. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    The table does not look familiar to me.
    Here is a link to a PDF from TI about reference designs.
    focus.ti.com/lit/an/slod006b/slod006b.pdf
    From chapter 16 filters are discussed, sallen-key from 16.3.
    Greetings,
    Bertus
  9. alialiali
    Dec 12, 2008
    26
    Thx a lot for the Pdf file but the problem it's very difcult 2 understand it can you please help me bit mor how 2 apply the formlu to my filter as I need band pass betwen 23k and 53k by uding 2 secound order sallen keys filter only
  10. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Here ia a PDF special on sallen key filters.
    Chapter 3 is for low pass
    Chapter 4 is for high pass
    Each chapter has simplifications in it.
    I used the calculator on the web to have the 23 kHz highpass filter
    .http://www.pronine.ca/acthpf.htm
    R1 = 4.89 k Ohm, R2 = 9.78 k Ohm and C1 = C2 = 1 nF
    The same I did with the 53 kHz lowpass filter.
    http://www.pronine.ca/actlpf.htm
    R1 = R2 = 2.12 k Ohm , C1 = 2 nF , C2 = 1 nF
    Greetings,
    Bertus
  11. alialiali
    Dec 12, 2008
    26
    Many many thx
  12. alialiali
    Dec 12, 2008
    26
    This two circuits is great just I’d like to ask how to connect them together so I get my final out put from one port instead to have tow deferent out puts port ?
    Do I need to implement a there’d filter to feed this two in it ?
    Please gave me some ideas
    Many thx
  13. alialiali
    Dec 12, 2008
    26
    When I contact them together as in the picture it gave me defrnt anwsers
  14. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    You can connect the highpass filter at the output of the lowpass filter.
    This will create the bandpass filter.
    Greetings,
    Bertus
  15. alialiali
    Dec 12, 2008
    26
    Thats great the high pass signal is ok as it's gaving me 23kHz but when I test the output for the 53k it's gaving me 61KHz so please can you gave more advice.
    I think we need to add another filter such as adder or first order filter
  16. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Perhaps a buffer between the highpass and lowpass will help.
    Greetings,
    Bertus
  17. alialiali
    Dec 12, 2008
    26
    Sorry but what do you mean with buffer as I have no idea a bout it at all
  18. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    A buffer is an opamp with the + as input and the output conected to the - input.
    When you place this between the two filters they will not "see" each other.
    Greetings,
    bertus
  19. alialiali
    Dec 12, 2008
    26
    Do you know what I learned hear from you I wouldn’t learn it in one year
    I greatly appreciate your kind help
    The result of the test now still negative as nothing changed do you think we need to add some resistors to the buffer ?
  20. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    What happens when you change the TL072 (wich has a bandwidth of 4 Mhz)
    to a LF357 ( wich has a bandwidth of 20 Mhz) ?
    Perhaps the limited bandwidth is giving some problems.
    (you are using rather high frequencies).
    Greetings,
    Bertus
