need help with rc motor, with constant rotation
Discussion in 'General Electronics Chat' started by rfwalker, Nov 24, 2009.
  1. rfwalker
    Nov 24, 2009
    Hi all, I need some help. I do not know much about rc servos but am leaning towards using one to accomplish my goal.
    basically I want a linear actuator that extends 8 to 12"
    and will continuously extend/retract slowly (.2 or .3"/sec), and will have no load.
    something like
    http://www.firgelliauto.com/images/flashpicis/track-actuator.gif
    would be ideal. but I can't spend that much and not sure I am competent to program it.
    I basically want to turn it on and have it extend/retract until turned off, unless I can use a PC interface to program it (something simple)
    because the above is so expensive, I was thinking of using a rc servo motor attached to a belt of some type to get the linear motion.
    but looking at phidgets rc motors, they state you have to remove a pot and replace with 2 resistors to trick it to go into continuous operation,
    so I am wondering if all rc are like this, I just simple want to be able to
    tell the rc motor to turn on and rotate at some velocity and don't stop
    till I tell it to
    can someone please help, I have been searching for a week and investigating linear actuators and don't think that fits the need either
    thanks, if there is a better/bigger forum where this could be answered, please send them my way. thanks rfwalker@hotmail.com
    happy thanksgiving
  2. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    How about a length of treaded rod attached to a simple, reversable, AC or DC motor. A nut would run up and down the rod at a constant rate if the motor speed was constant.
    The nut would have to be stabilized with guide rails to prevent it from turning and could hit a micro-switch at each end that would trigger a relay/circuit to reverse the motor direction.
    Good Luck
  3. rfwalker
    Nov 24, 2009
    thanks,
    can I ask another favor, can you recommend some parts
    I guess I need
    1) the screw/threaded rod
    2) the nut that can be held somehow from rotating
    3) a constant ac motor that can be reversed with flip of switch/circuit
    4) limit switches
    where do I get this, or at least could you be a bit more specific so I can
    search for google with some more specific parts
  4. ifixit
    Nov 20, 2008
    639
    110
    Items 1 & 2 you'll have to figure out yourself so that the results will suit your exact needs. (Google: threaded rod)
    You could use a 'drill driver' to turn the threaded shaft. Buy a cheap one or a used one and modify to suit. (Google: drill driver)
    The reversing switch on the drill would have to be re-wired so that it gets toggled at each end by the Nut. This will be a bigger mechanical challenge than an electrical challenge.
    Study all about circuits by clicking here: http://www.allaboutcircuits.com/vol_1/index.html
    Good Luck
  5. rfwalker
    Nov 24, 2009
    thank you, will start the google hunt
