What will happen to the clock speed (the output of pin 3) if you change the values of the resistors from 180k ohms to 1k ohms and the value of the capacitor from 0.22 µF to .10 µF? Will the ticks from the clock speed up or slow down? [HINT: The answer can be found here:
http://www.doctronics.co.uk/555.htm or
here: http://www.allaboutcircuits.com/vol_6/chpt_7/6.html and this is what the circuit looks like could you take a look and tell me the answer it has me puzzeled
Figure 1 Question 1
Figure 1 Question 1
