Need help with question......
Discussion in 'Homework Help' started by gregr, Sep 13, 2009.
  1. gregr
    Sep 13, 2009
    Here's the question, I have no idea what they are asking for an answer....
    Any help is greatly appreciated.
    Q#1- List all the resistance combinations possible using the three resistors 3, 9, and 18 ohms.
    Q#2- Wheatstone bridge - Given R2/R1 ratio as 100 and known resistor 4.7 ohms. Find the unknown resistor.
  2. mik3
    Feb 4, 2008
    4,846
    63
    Q1:
    Find all the possible series, parallel and series-parallel combinations of the resistors values given (and maybe each combination result in a different equivalent resistance).
    Q2:
    Depending where the unknown resistor is located (high side or low side of the bridge):
    100=4.7K/R
    or
    100=R/4.7K
  3. studiot
    Nov 9, 2007
    5,005
    515
    Q1 strictly don't forget to include the cases of only single resistors and two resistors. These combinations are possible because you could have a combination with all three but have one or two shorted out.
