Need help with projects(capacitor voltage/substitute part)
Discussion in 'The Projects Forum' started by 3dOptics, Dec 4, 2012.
  1. 3dOptics
    Mar 15, 2009
    13
    Circuit1:
    What should be the voltage rating of the following capacitors:
    47uF located across from switch. 50v?
    0.1uF capacitors that are connected to the opamps. 25v?
    Circuit2:
    Mouser Electronics shows that the component 74LX1G126 is discontinued. What component can I use to replace the 74LX1G126?
    Thanks.
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    60v on the 47uF.
    25v on the 0.1uF.
  3. Skeebopstop
    Jan 9, 2009
    358
    It is just a 3 state buffer. Check Element 14 and you'll easily find something if you search for tristate buffer.
