Hi All! I hope i am posting in the appropriate area/forum.
I have a project that i am trying to complete and am having a really hard time figureing it out. I had someone helping me design this but he fell off the face of the earth
I am putting together an electric pressure washer and need todo the following: when the sensor stops sensing the flow of water it triggers the relay but delay the motor shutting off for 10-15 seconds.
the key though is to have a 10-15 second off timer that way it doesnt stress the motor everytime if squeeze the trigger, especially walking around the vehicles. I thought i had this but realized the relay i found isnt robust enough to handle the motor.
These are the parts I was told to purchase: (Its Safe) https://www.dropbox.com/sh/wnltxzm3s2r90ob/AABvxZvtMgnW1gMqqkozEOlua
The flow sensor attaches to the output of the pressure washer pump.
And this is the motor I purchased http://www.baldor.com/products/deta...inglePhase&winding=36WGW903&rating=40CMB-CONT
I simply need a 10-15 second delay and someway to trigger the contactor and overload circuit (together make the "motor starter?")
At this point i think i need a transformer to drop down the voltage for a relay that attaches to the flow sensor ? Is the overload circuit my relay from the timer to turn the motor on?
I also assume for an ON/OFF switch I would just "break" the sensor wire?
I'm becoming frustrated because i just cant "get this" I feel like this is overly simple and i should be able to figure this out , but there is just not really any information out there on how todo this.
Im trying to build a box that looks like this:
It has an on/off switch-status light-reset switch
Thank you i really appreciate any help or guidance with this, i would also be willing to pay for someones time to come up with a diagram and remaining parts list.
