Need help with Power Supply Issue
Discussion in 'The Projects Forum' started by dlack, Mar 4, 2015.
  1. dlack
    Jan 3, 2014
    8
    I have an 800W power supply ballast that is suppose to distribute approximately 50V at #'s 5 & 6 when switch is on 115V (please see attached schematic). I'm getting a reading of 0 for each. I've tested resistors, Fets, diodes, bridge, IGBTs, thermal switch etc. They look good but not cancelling out that there could be something I missed regarding those. Additionally didn't see any visual damges. Any suggestions please?
    Thank you
  2. wayneh
    Sep 9, 2010
    12,388
    3,244
    Bad capacitors?
  3. dlack
    Jan 3, 2014
    8
    I'll double check those to see if problem is with them
    Thank you
  4. wayneh
    Sep 9, 2010
    12,388
    3,244
    Unfortunately only an ESR meter can tell good from bad, unless of course one has actually burst.
  5. kdcouture200
    Member
    May 22, 2010
    17
    Looking at your schematic it looks as if you have a dead short after C4. This would make the rest of the circuit useless electrically speaking.
    wayneh likes this.
