need help with power diodes questions
Discussion in 'Homework Help' started by minh tú nguyễn, Oct 12, 2016.
  1. minh tú nguyễn
    Oct 12, 2016
    5
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    Even if someone was of a mind to do your homework for you they couldn't since there is no question 5 to be found in any of those problems (in the image on flickr, the two images you tried to link are bad links -- might require someone to login to some third party site).
    You need to show YOUR best attempt to work YOUR homework. We can then try to help you find your mistakes and move towards a solution.
  3. minh tú nguyễn
    Oct 12, 2016
    5
    http://imgur.com/jHsD9Rb hi i tried to post it in this site. Hope it can fix the problem. And I tried my best to do it even after reading the book, I just couldnt
  4. minh tú nguyễn
    Oct 12, 2016
    5
    For Question 5 Problem 4 since diode 1 is forward biased in parallel with diode 2 which is reversed biased. I think there is no resistance between this 2 parallel diodes so to get Current I, my thought is I would just Use Vs divide by R to get Current I as I = Vs/R = 10/10= 1A. Since Diode 2 is reversed biased its current will be 0 and diode 1 will have 1A
  5. WBahn
    Mar 31, 2012
    18,079
    4,917
    There is NO question 5 in that image!
    Problem 4 has four questions. Problem 5 has one. Problem 6 has three.
  6. WBahn
    Mar 31, 2012
    18,079
    4,917
    That is correct (assuming you are treating the diodes as ideal, which it sounds like you are and that that is what the problem is assuming you will do).
    Though I still don't see any Question 5 associated with that problem.
  7. Dennis Ramlal
    Oct 12, 2016
    Im so sorry. What i was referring to was question 4 of problem 4. And also Im stuck at how to get the waveform for problem 5 and question 1 of problem 6. For question 2 I used Root 2 multiply with 50=70.7V to get Vmax and PIV, is it correct?
  8. Dennis Ramlal
    Oct 12, 2016
    Sorry I used my phone so it got signed on in different account but it's still me the one who post the thread
  9. minh tú nguyễn
    Oct 12, 2016
    5
    Im so sorry. What i was referring to was question 4 of problem 4. And also Im stuck at how to get the waveform for problem 5 and question 1 of problem 6. For question 2 I used Root 2 multiply with 50=70.7V to get Vmax and PIV, is it correct? Sorry I used my phone so it got signed on in different account but it's still me the one who post the thread
  10. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Here is a cropped version.
