panic mode
- Joined Oct 10, 2011
- 2,761
it works but there still may be problems. soldering is not clean and i see wire going over pad that belongs to different circuit. this is very risky - you may have project quit working (or maybe damage something) even if you sneeze. also where are the 330 ohm resistors? i see 33 Ohm, which means pic outputs driving transistors are overloaded (if the pic outputs could supply it, base current would be some 120mA).
