Would like to use something like a single or dual internally compensated 741 that can have a adjustabile 6 to 7 volt pull in point & about a .3 vdc lower drop out point . It will be used to control a 12 vdc relay that pulls .3 amps when energized.
This will controll the charging on 2 small gasoline motors battery charging. They have alternators & rectifiers. But no control of the battery being over charged. So the SPST relay needs a adjustible pull in setpoint & a adjustabile drop out setpoint.
A website with a diagram would be fine.
Thank you for any help.
Rich
Rich
