Need help with non-linear(?) Op-Amp circuit
Discussion in 'The Projects Forum' started by Jack_K, Jul 30, 2009.
  1. Jack_K
    Thread Starter Active Member
    May 13, 2009
    115
    I have a motorcycle with a gas gauge. The sending unit for that gauge reads 10 ohms when the tank is full and 215 ohms when the tank is empty. OK so far.
    I want to add a second gauge (2 total gauges). The second gauge requires a sending unit that reads 10 ohms when full but only 70 ohms when empty.
    So, if I simply parallel the two gauges, the additional one will read empty long before the tank gets empty (70 ohms vs 215 ohms). Also, I suspect that paralleling two gauges will make the original gauge read wrong, too. That really complicates the problem.
    I can't install an additional sending unit in a motorcycle tank. No way to do that.
    I measured with the second gauge since it's on my workbench. Here's what I got. I connected the 12 volt pin to a 12 volt gel cell battery that measured 12.8 volts. The sensor pin was connected to a 10-turn 100 ohm pot. The other end of the pot was connected to the battery's negative terminal. I then measured the voltage across the resistor (with a DVM).
    Voltage across the resistor Voltage across the gauge
    10 ohms - 1.06 v = 106 ma 11.74 v
    20 ohms - 1.82v = 91 ma 10.98 v
    30 ohms - 2.36 v = 78.6 ma 10.44 v
    40 ohms - 2.80 v = 70 ma 10.0 v
    50 ohms - 3.12 v = 62 9.68 v
    60 ohms - 3.41 v = 56.8 ma 9.39 v
    70 ohms - 3.63 v = 51.7 ma 9.17 v
    You can see it's nonlinear, but not too far off.
    I haven't measured the motorcycle's gauge. I'm going to try that ASAP. Then I’ll know the ratio between the two gauges.
    Attached is an op-amp circuit that I think will work. The op-amp will input the voltage across Gas Gauge 1 and amplify it to the correct level for Gas gauge 2. Right now I don't know exactly what voltage will be across Gas Gauge 1 since I haven’t measured it yet, but I do know the voltage required for Gas Gauge 2 is approximately 9.2 to 11.74 volts based on V1 being 12.8 volts. Of course V1 will be higher when the motorcycle is running, but I think the ratio will be close enough. After all, it’s just a gas gauge. Anybody ever seen an accurate gas gauge?
    I doubt that the two gauges need the same voltage so that would mean I need a non-linear differential amplifier(?) since both gauges need 10 ohms to read full, but they need totally different resistances to read empty (215 vs 70 ohms).
    Also, the op-amp will need to be able to source 100 ma or so.
    Anyone know how to do that?
    Jack
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This topic is a spin-off of this thread:
    http://forum.allaboutcircuits.com/showthread.php?t=25706
    ... to which I'd replied minutes before our OP started this thread.
    I feel that attempting to source current to your new gauge is going to complicate things considerably. It's much easier to sink current from the gauge.
    As far as linearity goes, the small non-linearity you are seeing in the gauge is nothing compared to what you're going to see from graphing actual quantity of fuel in the tank vs fuel level sensor resistance. I can only surmise that it will be wildly non-linear.
    As I mentioned in the other thread, you just haven't provided enough data yet; also, the voltage level of the battery from the first test is still in question.
  3. Jack_K
    May 13, 2009
    115
    "also, the voltage level of the battery from the first test is still in question."
    Because of the inherent inaccuracy of gas gauges, I didn't think I need be exact on the voltage level of the test battery. Also, the battery voltage on the motorcycle will not remain constant as I ride.
    I'm just looking for a ratio I think. Am I wrong here?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, we really need some baseline numbers here.
    You may not have realized it yet, but as the resistance of your simulated sensor increased from 10 Ohms to 70 Ohms, the resistance of the fuel gage also increased; from 110.8 Ohms to 176.8 Ohms. This is assuming that the battery measured exactly 12.8v throughout your test.
    You may be surprised here, too. Don't forget that your generator/alternator has a regulator in it to keep the electrical system at a nominal 13.8v when the engine exceeds about 1,000-1,200 RPM.
    Basically, yes. However, before we can even venture a guess as to what that ratio might be, it would certainly be nice to have some readings to kick around - preferably, readings that were made under like conditions.
  5. John Luciani
    Apr 3, 2007
    477
    As was mentioned you could be a lot better off sinking current. I am wondering if a
    current-sink that mirrors but attenuates the current from gauge one would work
    (see the attached circuit).
    (* jcl *)
    NB: This idea was generated B.C. (Before Cappuccino) :)
  6. Jack_K
    May 13, 2009
    115
    That sounds like a good idea but the MOS-FET, or whatever it is, is over my head. What connects to the two inputs?
    Jack
  7. Jack_K
    May 13, 2009
    115
    I was finally able to measure the voltage across the motorcycle's gas gauge. Using the following resistances I obtained the corresponding voltages:
    Ohms Volts
    10 --- 7.95 FULL
    20 --- 7.57
    40 --- 6.80
    70 --- 5.81
    100 -- 5.00
    150 -- 3.97
    175 -- 3.55
    200 -- 3.15 EMPTY
    215 -- 2.95
    The gauge I want to add produced the following voltages:
    Ohms Volts
    10 ---13.4 FULL
    20 --- 12.47
    30 --- 11.88
    40 --- 11.284
    50 --- 10.86
    60 --- 10.56
    70 --- 10.295 EMPTY
    So now I need a way to make the 2.95 to 7.95 volts be 10.295 to 13.4 volts for the second gas gauge.
    If it were linear I could do it (I think), but it's not linear. The ratio of the voltages goes from approximately 1.685 to 3.5.
    Any ideas?
    Jack
  8. John Luciani
    Apr 3, 2007
    477
    It seems like it is pretty close to linear. A little hard to tell since you
    have 8 points for tank1 (E to F) and only 7 for tank2.
    Using tank 1 as x and tank 2 as y --
    y = mx + b
    m is the change in y divided by the change in x.
    m = (7.95 - 2.95) / (13.4 - 10.295) ~ 3/5
    To find b we will plug in a value for x and y. Let's use the first point --
    y = (3/5)x + b
    13.4 = (3/5) * 7.95 + b
    b = 8.63V
    The amplifier needs to have a gain of 3/5 and you need to add 8.63V to the input.
    The equation would be
    Vtank2 = (3/5) * Vtank1 + 8.63V
    The end points are correct. You could test the points in the middle.
    They may be close enough. If not I would use a uC and a lookup table.
    (* jcl *)
  9. Jack_K
    May 13, 2009
    115
    Thanks! Great information. I was trying to figure out how the slope equation would fit but I was lost (have been out of college for 45 years).
    If I take the exact slope, .621, instead of .6, the voltage works out to be 8.46. I'll call it 8.5 volts. That's easier to use.
    A gas gauge is not an exact science so I'm sure this will be close enough. It's not worth using a uC.
    Thanks again,
    Jack
  10. Jack_K
    May 13, 2009
    115
    Sgt Wookie posted this schematic. Now I need to make it have a gain of .6 and add 8.5 volts. I don't know how.
  11. John Luciani
    Apr 3, 2007
    477
    Probably not in this case since it can be done with a single op-amp and
    a handful of resistors.
    But a $2 uC would work too. You can get a development board for around
    $30 that programs from the USB port of any computer. The software tools
    are free.
    This would also be a good first program.
    1. Read a voltage.
    2. Calculate y = mx + b
    3. Output a voltage.
    4. Go to step 1.
    (* jcl *)
  12. Jack_K
    May 13, 2009
    115
    Thanks John. I'd have no problem programming a uC. I'm an Embedded Software Engineer by trade. Been programming everything from 4 to 32 bits for years.
    I just don't want to fool with that much circuitry stuck inside the tight confines of a motorcycle.
    Jack
  13. Jack_K
    May 13, 2009
    115
    Will this work? I'm not great with analog design.
    Jack
  14. Jack_K
    May 13, 2009
    115
    Does anybody see anything wrong with the circuit in the preceding post?
  15. John Luciani
    Apr 3, 2007
    477
    That looks like it will convert between the two different voltage levels.
    You could probably do it with a single op-amp.
    (* jcl *)
  16. Jack_K
    May 13, 2009
    115
    How to do it with a single op-amp?
  17. John Luciani
    Apr 3, 2007
    477
    Use the non-inverting input to perform the summing. A little bit more to
    calculate. See if there are some op-amp examples in the AAC text.
    (* jcl *)
  18. Jack_K
    May 13, 2009
    115
    Yes. I could use a non-inverting summing amplifier but it would only save two resistors. For some reason I'm more comfortable with inverting op-amp circuits. Am I wrong?
    Jack
  19. John Luciani
    Apr 3, 2007
    477
    It would save an op-amp and two resistors.
    The circuit you have drawn is easier to understand.
    (* jcl *)
  20. Jack_K
    May 13, 2009
    115
    I realized that my circuit is backwards. I mean it will convert gauge 2 to gauge 1 but what I need is to convert gauge 1 to gauge 2. So, instead of an adder, I need a subtractor.
    I had a lot of trouble doing that with a non-inverting op-amp so I had to put an inverting op-amp in front of it. Will this circuit actually do what my note says?
    Jack
