Need help with my final year project...
Discussion in 'The Projects Forum' started by navarro_boyz, Jan 20, 2012.
  1. navarro_boyz
    Jan 20, 2012
    Hi guys.
    I am a final year student of Beng Electrical and Electronic.I am currently doing a project titled "heart rate measurement using fingertip" by Dogan Ibrahim and Kadri Buruncuk @ http://www.emo.org.tr/ekler/a568a2aa8c19a31_ek.pdf and i have modified the circuit and the programming based on my ideas.Therefore, I would like to ask your help in order to check whether there is any problem with my circuit diagram and also with my programming code since i have modified the project on my own.In the hardware side, it works fine but i could not simulate it on the proteus and i suspect that there might be a problem on the circuit part that i may have overlooked.If there is no problems,then only i can do the etching process.
    The original circuit by Dogan Ibrahim and Kadri Buruncuk.
    [​IMG][​IMG][​IMG]
    My modified circuit.
    [​IMG][​IMG]
    I added the buzzer on the pin 18 and the "abnormalities" led on the pin 17 of the pic16f784a.In addition,I also added the "on" indicator led with the +9V and the "reset push button" through the pin 4 of the pic16f84a.The programming also have been done according to the changes desired.
    The original operation of the project...
    BEGIN
    Initialize program variables
    Configure input-output ports
    Display message “READY”
    Wait until switch is pressed
    Sum = 0
    DO 3 times
    Get count in 10 seconds
    Count = 6 * Count
    Sum = Sum + Count
    ENDDO
    Calculate the average, Rate = Sum / 3
    Display the average on the LCD
    END
    My desired operation of the project...
    BEGIN
    Display message "PRESS START"
    Sum = 0
    DO 3 times
    Count = 6 * Count
    Sum = Sum + Count
    ENDDO
    Normal heart rate
    Beep once using buzzer
    High or low heart rate
    Beep three times using buzzer
    Led blinking continuously
    END
    The rest of the information are attached together with this thread.
