Well the Gootch is all finished, however i've made what seems to be a big mistake.
I have set the ESC up so that full throttle/collective is when the transmitter stick is pulled back and vice versa. In my excicitment I had the throttle closed at the start of the set up instead of open.
Can i reset the ESC, or will i require a new one; i've tried going through the set up process again but can't reverse the problem
I'm desperate to fly this baby, so all advice is welcomed.
