Need help with Mosfet limitations
Discussion in 'General Electronics Chat' started by Jcfynest, Jun 8, 2007.
  1. Jcfynest
    Jun 8, 2007
    Does anyone know any websites/journals/books that can tell me the speed and size limitations of a standered mosfet? Im having trouble geting a straight answer.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    They are called datasheets and they are published by the manufacturer. At least for speed. You can tell by the numbers there how long it takes to charge the gate capacitance, and how long it takes to remove it. Don't expect high speeds and high drain currents at the same time.
    With respect to size I'm more uncertain. If you mean package size and dimensions then the datasheet is the place to look. If you mean the size of the die then I'm at sea.
  3. n9352527
    Oct 14, 2005
    1,198
    Probably because no one knows what you meant by a standard MOSFET.
  4. John Luciani
    Apr 3, 2007
    477
