need help with load cell
Discussion in 'General Electronics Chat' started by bug13, Jan 21, 2014.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    I have some trouble understanding a load cell, take this one for example:
    http://edg.uchicago.edu/tutorials/load_cell/FX1901.pdf
    I don't know how to work out the voltage output and force/weight ratio.
    what does mV Output: 20 mV/V Nominal mean in the datasheet? I am kind of expecting xyz Newton or Kg / mV or something.
    but all the tutorial I read need to put a known weight and work out the weight/mV ratio.
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    it means at full scale, it will give you 20mV for every 1V you apply to it.
    So if your load cell is rated 200LBS max and you apply 10V of excitation current, and you load it with the full 200LBS, it will output 200mV.
    (100% load X 10V X 20mV/V)
    If you load it to 50LBS you will get 50mV
    (25% load X 10V X 20mV/V)
    bug13 likes this.
  3. bug13
    Feb 13, 2012
    1,213
    38
    Thanks now I understand, I think you mean 10V of excitation voltage above as well?
    Another question, are all the s beam load cell expensive? I am looking for a s beam load cell, be able to handle +/-500N, they are like over $4-500, are there any sub $100 ones? I don't need very high accuracy.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    yes, look at ebay and amazon. I was looking at sub-$100 load cells recently
    bug13 likes this.
  5. strantor
    Oct 3, 2010
    4,302
    1,989
  6. wayneh
    Sep 9, 2010
    12,374
    3,226
    Read note #1 in that pdf: The output is a ratio of the supply voltage. So if full scale is 20mV/V and you supply 5V, AND the full scale is 100lbs, you'll get an output of 1mV per pound.
    Oops, should've refreshed first.
    bug13 likes this.
  7. t06afre
    May 11, 2009
    5,939
    1,222
    Ah yes load cells can be tricky for the beginner to understand. Load cells like the one you have have need a excitation voltage. And the output will a differential readout across the bridge. So the the 20mV/V means for each volt used as excitation voltage. The differential reading at full load will be 20mV times excitation voltage. Using 1 volt as excitation the differential output reading will be 20mV using 2 volt 40 and so on.
    http://www.sentranllc.com/pdfs/tb_accu.pdf
    bug13 likes this.
  8. bug13
    Feb 13, 2012
    1,213
    38
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    both of those are >10X your budget
  10. bug13
    Feb 13, 2012
    1,213
    38
    :D I know, I am just curious, want to know the different why there are two type. Not that I am going to buy those.
  11. bug13
    Feb 13, 2012
    1,213
    38
