Need help with LM3914 VU Meter
Discussion in 'The Projects Forum' started by AlessandroS, Jan 25, 2014.
  1. AlessandroS
    Jan 25, 2014
    Hello all,
    I recently picked up a LM3914 to play around with before I started designing a VU meter. I want to simultaneously drive a speaker or headphones, so I need to mitigate the loading effect of putting a relatively small resistance in parallel with the input of the LM3914.
    I figured a unity gain buffer would do it, but for some reason, it simply causes all the LEDs to light up. Anyone able to perhaps explain why that's happening, or suggest an alternative? My circuit was working fine until I tried this.
    Also, this is hard to describe, but is there a way to "smooth out" the output? I tried a peak detector, which again didn't do anything.
    Thank you,
    AlessandroS
  2. GopherT
    Nov 23, 2012
    6,303
    4,020
    Sound (audio) power is a log, not linear measurement. Use the lm3915 for audio.
    The lm3914 is linear
  3. AlessandroS
    Jan 25, 2014
    Thank you for the suggestion, I take it that the LM3915 is a solution to my second issue?
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Take a look at the following project of ESP:
    http://sound.westhost.com/project60.htm
    You can also have a look at the LM3916, wich is specialy made to create a VU meter.
    The attached datasheet will give a number of schematics.
    Bertus
  5. ericgibbs
    Jan 29, 2010
    2,587
    389
  6. AlessandroS
    Jan 25, 2014
    Thanks everyone!
    I think I'll go with that ESP link, then maybe try a 5 or 10 band version once I've completed that.
