need help with lm324
Discussion in 'The Projects Forum' started by janosandi, Oct 16, 2013.
  1. janosandi
    Dec 29, 2009
    7
    hello guys
    im not good with analogue curcuits
    i need a circuit to check a voltage if its 6 or 12 v & activate 2 relays depending on this
    any help will be appriciated
    ِACTUALLY i hink to check if volt is >6 or < is enough
  2. BobTPH
    Jun 5, 2013
    806
    121
    You need to be more specific. The relays should be on only if the voltage is exactly 6 or 12V? That is pretty much impossible. So please explain exactly what the relays should do for 0-6V, 6-12V and above 12V.
    Bob
  3. janosandi
    Dec 29, 2009
    7
    thx Bob
    i want to activate 1 relay when i have volt between 4-6 & activate the other when its >6-12 & shut the first one off
  4. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    You could use a couple of comparators LM311 maybe and activate the first when something just below 6v and the other when just below 12v and a N.C. contact on the second relay in series with No1 coil.
    Specifics of the application would help.
    Max.
  5. janosandi
    Dec 29, 2009
    7
    Thx Max
    i'll download the datasheet & work on it tomorrow
    maybe i need ur help if u r familiar with it
  6. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    LM393 is a dual package.
    Max.
  7. janosandi
    Dec 29, 2009
    7
    i have lm324 already does it work with me ?
    it has 4 comparators i know but how to do tht i searched for examples of doing such thing i didnt find
  8. #12
    Nov 30, 2010
    16,664
    7,311
    It depends on how accurate you need it.
    Here's a crude form that is kinda close.
    Forgot to use an amplifier chip.
    Oh well.
    janosandi likes this.
  9. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    That should work for a simple comparator.
    Is the voltage constantly varying, does it return to zero after >12v is reached?
    Max.
  10. janosandi
    Dec 29, 2009
    7
    no its exactly 13-14 or 17-18
    its an output of digital receiver
    when its 0 its not important wht its doing i need to to know if its in 1st or 2nd condition
  11. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    You can set up something like a LM339 as a dual window comparator which has MIN - MAX out or when the minimum is reached.
    Do you need the window option?
    Or what is the desired range and operating points?
    Desired ON OFF or Don't Care voltage points.
    Max.
  12. janosandi
    Dec 29, 2009
    7
    on off will be ok with me & no problem which its on or off
    the volt range for the first condition is 13-14
    & the other is 17-18
    Thx Max
  13. BobTPH
    Jun 5, 2013
    806
    121
    What happened to 6 and 12?
    Bob
  14. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    You could try something like this, hopefully your voltages are steady?
    Max.
  15. janosandi
    Dec 29, 2009
    7
    thx Max
    i'll buy lm 339 today & try it but i couldnt understand wht resistors i've to put for the inputs U've put 6 value how to decide wht to use ?
  16. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    The LM339 is a quad package so you need all four, the other 2 is just a duplicate of the first two, the two sets of resistors are for each window pair.
    For the LM339 you may want to change the 750Ω base resistors to 1.5k.
    Max.
  17. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    See modified PDF.
    Max.
