Need help with limiting resistors
allahjane
Joined Sep 19, 2012
75
Hello all,
I'm using a motor driver for my application that has been rated as 5 Amp max but the load can leech more than 5 Amps if that much current is available.
I'm using a 12 v power source
However my power source may vary over time and may exceed 5 Amp but voltage will always remain at 12 v
So if I connect a 2.4 Ohm resistor in series then as per ohm's law the current will never exceed 5 Amps.
Is that correct?
also if when I use a power source with less supply than 5Amp will the limiting resistor lower the current further?
ErnieM
Joined Apr 24, 2011
8,377
A 2.4 ohm resistor on a 12V supply will indeed limit current to 5amps, but only when there is no load (or it shorts directly to ground without any other parts). If you add a load then the current goes even lower.
If this is for the L298 in your other post then that only has (each channel) a 2A average current, and 3A single peak.
Rather then limit current you could sense current and trip a turn off circuit. I say "trip" as it needs a flip flop or delay to keep the H bridge off: a simple comparator will allow it to turn right back on.
allahjane
Joined Sep 19, 2012
75
Sort of, but I want to limit the current to safe value and not to shut it down completely
34,285
I don't understand how your load can take (leech?) more than its rated current if the supply voltage doesn't change? :confused:
But if you really need a limiter, below is a two-transistor circuit that will limit the current to 5A. The circuit limits when the voltage across R3 reaches about 0.65V.
Note there will be a small voltage drop at the output due to the load current through the 0.13Ω resistor.
The P-MOSFET can be any 10A or larger device.
If the limiter operates under a continuous limit condition then the MOSFET must be mounted on an appropriate heat-sink.
