I need some help with an idea I have about a project. I want to make a sequence of six LEDS, but I don't want them to just run in sequence when I apply power. When turned on, I want LED1 to light, then when you press a button, LED1 turns off and LED2 turns on. Press the button again and LED2 goes off and LED3 turns on. And so forth until the end, then have the process repeat.
I don't want to use Arduino or a PIC or STAMP chip. I was thinking of doing some type of circuit with a 555 and a 4017. I have made "knight rider" chasers in the past and I'm sure that can be modified in some way to have the sequence break when the button is pressed. Just can't quite figure it out.
I appreciate all the help!
