Hello everyone and thanks for reading this post.
I'm by no means skilled in electronics and I really don't know much beyond very simple circuits. I am a plumber by trade and have a sewer camera (basically waterproof camera with lights mounted on the end of a fiberglass cable) that I'm attemping to rebuild on my own.
My question lies in the PCB for the LEDs of the camera. The original LEDs were red which work fine for a B&W cam but it will be replaced with color and I needed to switch these LEDs over to white. Well, I removed the LEDs and cleaned up the PCB, but I failed to make a note of how the original LEDs were installed and now I'm a little confused.
From what I could tell, there may be one ground in this whole sequence and three power sources. (3 white wires, and one green - green was attached together with camera ground while white wires each had a separate connection point).
Excuse the crude MS Paint lines, but can anyone make sense of this?
Thanks so much in advance for your help and ideas!
