Need help with led circuit
Discussion in 'The Projects Forum' started by grognak, Nov 2, 2015.
  1. grognak
    Nov 2, 2015
    7
    Hello everyone,
    I am trying to figure out what I need to complete a project I am working on. I am trying to run 9 of these Leds http://www.amazon.com/gp/product/B0059H5YUK?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01 from a AA battery pack for a prop I am making. I will also be adding a toggle switch. I was wondering if anyone could tell me if the resistors it comes with will work or if I will need other ones and If the system will be efficient enough to run for a little while. Im concerned that I will either burn up my leds or it will drain the batteries in 10 minutes. I know nothing about wiring leds and could really use some help designing an efficient wiring schematic so my prop will stay lit for a while. thank you everyone.
  2. #12
    Nov 30, 2010
    16,703
    7,338
    Nobody can tell without the resistance rating of the resistors and how much voltage you are going to apply.
  3. grognak
    Nov 2, 2015
    7
    ok, :/ Im pretty lost here but I think 2 AA batteries would be 3v correct? I know the resistors are 1/4 watt but don't know the ohms. is there any way you would be able to let me know what resistors I would need based off of 2 AAs and 9 of those leds? should I use something besides AAs?
  4. Dodgydave
    Jun 22, 2012
    5,154
    772
    Says 2v drop, probably 120 to 330 ohms resistors,
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    They seem to be 100 ohm 2% (brown-black-black-black-red)
    and the LEDs seem to be 2Vf
    so (3V-2Vf)/100 = .01 Amps (or 10mA) which is perfect for long life..
    So with 2 x AA batteries you need to make 9 strings of an LED and resistor in each string..
    grognak likes this.
  6. grognak
    Nov 2, 2015
    7
    thank you very much! I am still a little confused as to how to wire them together to the power supply. (sorry, this is my first electrical project and its all foreign to me) also, would the resistor go be fore the led on the positive leg or after the led on the negative? thanks again for your help.
  7. mcgyvr
    Oct 15, 2009
    4,791
    976
    I updated my post to show a schematic... and the resistor could be before OR after the LED.. it doesn't matter..
    Think of the resistor as a "water valve"... It doesn't matter where it goes as it "sets the pace (sets the current)" for the whole garden hose.. The water (current) can only flow as fast as the valve allows it in the whole circuit.
    grognak likes this.
  8. grognak
    Nov 2, 2015
    7
    just refreshed and saw the diagram you made. thank you so much! I think I can figure that out :) youre the best
  9. grognak
    Nov 2, 2015
    7
    if I wanted to add a toggle switch in line I would do it on the positive leg correct?
  10. mcgyvr
    Oct 15, 2009
    4,791
    976
    That would be "recommended" but in this situation it really doesn't matter..
    But its usually always safest to disconnect the "non-grounded" connection.
    grognak likes this.
  11. grognak
    Nov 2, 2015
    7
    Thank you!
  12. grognak
    Nov 2, 2015
    7
    out of curiosity, how bright do you think the leds will shine in this setup?
  13. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Compared to what? My guess is that they won't be as bright as the sun.
  14. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    This might help:-
    http://www.talkingelectronics.com/projects/30 LED Projects/30 LED Projects.html
