need help with Jfets
Discussion in 'Homework Help' started by shikk, Jun 22, 2014.
  1. shikk
    Jun 22, 2014
    Hi, can someone please help. I'm studying for my exam and i have no idea how to solve this Jfet circuit
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Do you manage to identify the JFET type?
    Do you know the equation which describe Id vs Vgs ?
    Id = K*(Vgs - Vp)^2
    And if you look at the circuit Vgs is equal to ??
  3. shikk
    Jun 22, 2014
    Yes i did. its a P-channel Jfet. I do not no what vGS is equal to. I said the current, ID=vs/100 and VGS=Vs(vs is the voltage across the 100 ohm resistor ). plugged both into the equation and got a value for Vs. from that value i got the current ID, and then the voltage Vr. is this correct? is the 20V the value of Vss?
  4. shteii01
    Feb 19, 2010
    3,516
    515
    It look like:
    VR1+Vsd+VR=20 volts
    VR1+Vsd+R2*Id=20 volts
    VR1+Vsd+R2*[K*(Vgs-Vp)^2]=20 volts
    It looks to me like VR1 is Vgs. If so:
    Vgs+Vsd+R2*K*(Vgs-Vp)^2=20 volts
    R2 is known
    K is known
    Vp is known
    If we knew Vsd, we could solve for Vgs, then plug Vgs into Id formula, then use Ohm's Law for VR=R2*Id.
    I think I am missing some assumption somewhere. Either for Vgs or Vsd.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    The idea is to find Id first using the known conditions with the FET in the saturation region - for (say) the case of R2=1K. In this case Id would notionally be independent of R2 for ideal behaviour. Since the circuit behaves very much like a current source one is then required to consider the limiting conditions as the load R2 increases and the FET enters the linear (triode) region.
  6. shteii01
    Feb 19, 2010
    3,516
    515
    Isn't in saturation Vgs=0?
    So Id=0.001(0-4)^2=0.016 A
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    FET's are considered as operating in the active region when in saturation. Vgs is the controlling parameter which in relation to the pinch-off voltage determines the active region saturation current.
    At Vgs=0 the device current is the parameter Idss - the saturation current at zero gate-to-source voltage.
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    Very good except one small mistake.
    Vs = Vss - Id*R1 and Vgs = Vss - Vs so from this we can say that Vgs = Id*RS.
    So we have
    Id = K*(Vgs - Vp)^2 = Vgs/R1
    And after we solve this
    http://www.wolframalpha.com/input/?i=10^-4*%28X+-+4%29^2%3DX%2F100
    We have Vgs = 0.14835V and Id = 1.4835mA
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    No; JFET is in saturation when Vds > (Vgs - Vp)
    And also check your math
    K = 10^-4 = 1/10000 = 0.0001
  10. shikk
    Jun 22, 2014
    What happens if both Vgs values where smaller than vp? how will you know which one to choose?
    thanks
  11. Jony130
    Feb 17, 2009
    3,993
    1,116
    Very unlikely to happen. But maybe you have some example ?
