Need Help with HV system
Discussion in 'General Electronics Chat' started by n_uhnak, Mar 11, 2010.
  1. n_uhnak
    Mar 11, 2010
    I am working on the development of a High voltage chemical sensor, and I have run into a little hiccup.
    I was looking for some common things that would blow a resistor, and if a relay switch could be stuck on a setting.
    Any help would be appreciated.
  2. retched
    Dec 5, 2009
    5,201
    313
    Too much current can blow a resistor, and relays CAN have their contacts welded together from too much current, causing them to fail in a particular 'setting'.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Exceeding the power dissipation rating of the resistor will do it every time.
    Select a resistor with a wattage rating that is twice what is required.
    Power in Watts = Voltage x Current = VoltageSquared / Resistance
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If there is several amps current involved with a few hundred volts, it's amazing how much of an arc will jump between relay contacts. They weld together easily after that.
