Something needs to be clarified:
1. The AC input is 120Vac,0V or +120Vac, -120Vac, because they are complete different.
2. If the input is 120Vac, when it through a bridge rectifier then the output will be a pulse DC, not a pure DC voltage.
3. If the input is 120Vac, when it through a bridge rectifier with a capacitor and then the output will be a Vdc, and the output Vout = 120Vdc * 1.414 = 169.68Vdc, so how can you get the 110Vdc?
4. The voltage you labeled (12V DC -), is that a 0V or real -12V? (in the left bottom)
5. What is the spec of DC motor(Volt/Amp)?
6. About the pin G of N-mosfet FQPF45N15, it has no any resistor connecting to D and S, that is no circuit loop, so the mosfet may not works properly, and there is no any protection for the Vgs, so it could be damaged the mosfet.
