Need help with high current voltage limiting
Discussion in 'The Projects Forum' started by capitanfracassa, Oct 12, 2009.
  1. capitanfracassa
    Oct 12, 2009
    I am running an AC HID lamp on a battery through an inverter, with the following constraints:
    1. The voltage of the battery range from 16.5V when full to 12.5V when depleted.
    2. The inverter has a 15V high voltage shut-off and a 10.5V low voltage shutoff.
    3. The LAMP + control gear consumes about 25W. Assuming the inverter also consumes something, I think the current draw from the battery is 2A-2.5A.
    without modifications, the lamp won't run if the battery is charged over 75-80% capacity.
    As a temporary kludge, I placed six MUR810 8A diodes in series. That works, but it means I have a 5W hip warmer that I really don't need.
    looking for a magic bullet, but I'll settle for a silver one ;-) Any ideas?
    Thanks for reading.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    You could use a buck-boost converter.
    This will regulate down in the input is to high and up if the input is to low.
    With the LM5118 you could make a converter to give 12 Volts constant at the output.
    http://www.national.com/pf/LM/LM5118.html
    The datasheet has some example schematics.
    On page 23 there is an example for 4 - 70 volts input and 12 volts output.
    Greetings,
    Bertus
  3. capitanfracassa
    Oct 12, 2009
    Thanks! .
