Need Help with Full wave rectifier in Pspice
Discussion in 'Homework Help' started by MarsG, Sep 14, 2015.
  1. MarsG
    Sep 12, 2015
    24
    My homework assignment is to design a Full Wave Bridge Rectifier (Attached the circuit I built in pspice and the full description of the assignment below.) The rectifier is to have a filter Capacitor across the Load.
    Given:
    Input = 120v-rms, 60Hz
    Load = 155 Ohms
    Voltage Across individual diodes = .7V (1.4 together)
    The Avg Outpt Voltage is to be 15v with a ripple of +- 1V peak
    Calculations
    120V-rms = 170v pk (Vrms= Vpk/sqrt2)
    with the voltage drop from the diodes (1.4v)
    The transformer has a ratio of 170:17 and a inductance ratio of (1/10)^2
    The ripple frequency is double the source
    60Hz----> 120Hz
    Iload= 15V/155Ohms
    Vripple = Iload/fC
    The transient analysis does not seem right, can someone help me figure out the problem (wiring or maybe the wrong capacitor value).
    I attached a screenshot below.
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    The filter capacitor must supply the total load current for ~8ms until the next current pulse arrives from the FWB.
    To achieve a given amount of ripple, use the following method.
    I*t = q = C*ΔV
    Rearrange and solve for C
    C=I*t/ΔV
    ΔV (ripple) = 1V, so C= I*0.008/1 = 8*I mF = 8*(15/155)mF = 0.77mF = 770uF (Much bigger than you calculated...)
    Russmax likes this.
  3. MarsG
    Sep 12, 2015
    24
    Thank you, I hellso.png had originally put 800uF but thought it was wrong and took another approach, My marker was also in the wrong place.
  4. shteii01
    Feb 19, 2010
    3,500
    511
    I thought they said ripple is +-1 volt, would that make delta V = 2 volts?
  5. MikeML
    Oct 2, 2009
    5,450
    1,066
    The problem spec is somewhat ambiguous, but if so, that would cut the required cap in half...
  6. MarsG
    Sep 12, 2015
    24
    Oh, I misunderstood it, I thought it was +- 1 of 15V lol.
  7. Russmax
    Member
    Sep 3, 2015
    81
    12
    I'm pretty sure the ripple spec means he cannot go below 14V. Or above 16V.
    Regards
  8. shteii01
    Feb 19, 2010
    3,500
    511
    Your average is 15 volts. (14+16)/2=15 volts, that is your average. So the highest value you can have is 16 volts. The lowest value that allowed to have is 14 volts. The delta V is 2 volts, 1 volt above 15, 1 volt below 15. You must stay in this "band" between 14 and 16 volts.
  9. MarsG
    Sep 12, 2015
    24
    Should I use a lower input peak voltage at 160V to get a 15V at the output cause right now it seems im slightly above the 16V peak at output
  10. shteii01
    Feb 19, 2010
    3,500
    511
    I think the ripple is given to you to figure out the smoothing capacitor. Just use MikeML formula to get the capacitor.
  11. MarsG
    Sep 12, 2015
    24
    Is the sine wave supposed to drop under 0, cause the peak voltage from peak to peak is actually 17
  12. shteii01
    Feb 19, 2010
    3,500
    511
    Forgive me for asking this, but: Why do you give a damn?
    You are given an input.
    You are asked to produce output.
    You are given some details about what should be placed between input and output. Everything else is up to you. If the output of the transformer is something... Is that part of your assignment? Are you required to produce transformer output that have particular behavior? Because if you are... I can not find this part of your assignment. Are you holding out on us?
  13. MarsG
    Sep 12, 2015
    24
    Not really, I just don't want to be marked off for anything so im including everything.
    Is their any way to read the values on the simulation from the markers in order to get the current values.
  14. shteii01
    Feb 19, 2010
    3,500
    511
    Ok. About that sign wave. Check a few things:
    1. Are you sure the signal has settled? I noticed in your assignment that they note that you want to wait for signal to enter steady state. So maybe if you wait, that signal will rise up and be, like you said, from 0 to 17 volts.
    2. Check if the simulated components have some offset.
    Is your input signal 120 VAC RMS centered on zero? Or is it from 0 to 120? Stuff like that.
    You should be able to get current readings by placing current meter in series. So if you want current thought R1, put current meter in series with R1. If you want current through D2, put current meter in series with D2. And so on.
    Finally. Remember that your diodes drop 0.7 volts each, 1.4 volts total. I think you noted that yourself. So you actually want output of the transformer to be 16+1.4=17.4 volts. I would be happier if I did not actually hit 16 or 14. Just stay inside the band, that is why they gave you that +-1 volt band to contain the ripple.
  15. MarsG
    Sep 12, 2015
    24
    How would I be able to center it at 0 in pspice? by using an offset?
  16. shteii01
    Feb 19, 2010
    3,500
    511
    Hm... I don't use PSpice. For general use I got old copy of MultiSim Textbook Edition that I got with a textbook back in 2000-2002.
  17. MarsG
    Sep 12, 2015
    24
    Oh alright. since the output is supposed to be 15V at the load I just added the voltage drop from the diodes (1.4V) at the transformer secondary to be 16.4 and it came down closer to 15V. 169.7 : 16.4 ratio 120V-rms*sqrt(2)=169.7 peak
  18. shteii01
    Feb 19, 2010
    3,500
    511
    Yes, but now your load voltage drops below 14 volts and that is bad. Your ripple must be between 14 and 16 volts, that is requirement of your assignment.
