Need help with elevator controller vhdl code
Discussion in 'Homework Help' started by Mirotvorez113, Nov 30, 2011.
  1. Mirotvorez113
    Nov 30, 2011
    Hello.
    As the topic states, need help with vhdl part of the assignment. The controller itself is what I cannot figure out, also need to emplement a 7 segment display and be uble to update the display but I do have the display code done. I got the debouncer and timer as well.
    In particular, it is a 11 story building(basement, loby, 0, 1, ..., 9)
    Inputs:
    4-bit dip switches for floor section
    Push button for detecting the doors
    Outputs:
    Left seven segment display
    Right seven segment display
    1 LED light to determine if the doors are open or not
    I was trying to use only 4 states thats the basic stuff I got so far:
    // elevator code
    module detectorcode(detect, clk, in, w, x, y, z, a, b, c, d, e, f, g, LED);
    input clk, in, w, x, y, x, A[], B[];
    output detect, a, b, c, d, e, f, g, LED;
    reg [2:0] state;
    reg detect;
    parameter A=3'b0000, B=3'b0001, C=3'b0010, D=3'b0011;
    always@(posedge clk)
    case(state)
    A:begin
    detect=1;
    if(in==1)
    state<=B;
    else
    state<=A;
    end
    B:begin
    if A[]-B[]>1;
    state<=C
    else
    state<=D;
    end
    C:begin
    D:begin
    endcase
    endmodule
    The rest I dunno:(, cause I'm clueless with vhld, let me know what other info I need to provide.
    Please really need help. Thank you.
