Hello Everone,
I am working on a project that requires me to convert AC voltage to regulated DC supply for DC loads upto 500 W. Below are the important specifications for my converter design.
I am thinking to use a center tap isolating transformer after the AC power source (use two diode arrangement for rectification) and use some sort of filters (LC-flters) and and finally employ use DC-DC converter thereafter. My challenge is to what shall I use as a switch for the DC-DC converter. I was thinking about using MOSFET. With it, I need to come up with some kind of design to control the cycle (some sort of PWM circuitry). I would really appreciate if anyone could help me with this stage of my project.
Thank you so much,
prince123
Input Voltage 120VAC
Output Voltage 24VDC
Output Current 21.0Amps
Load Regulation +/-0.5%
Line Regulation +/-0.5%
Ripple/Noise: 10mV Peak-Peak
Overload Protection 105-135%, Pulse Mode
Input-Output Isolation 1000VDC minimum
Efficiency 75% or better
Oper. Temperature with Derating: -40 to +60 DegC typicalOutput Voltage 24VDC
Thank you so much,
prince123
