Need Help With Cutoff Frequency
Discussion in 'Homework Help' started by Mawangs1, Apr 23, 2013.
  1. Mawangs1
    Mar 26, 2012
    23
    I'm getting confused. I'm trying to make a sallen key low pass filter where it's been established that R1 = R2 and C1 = C2.
    ω = 1/sqrt(R*C)
    Let's say I want to make an active lowpass filter that cuts out all frequencies above 400Hz.
    With this in mind, I would do:
    (1) 400 = 1/sqrt(R*C)
    (2) plug in a random C value
    (3) solve for the R.
    I'm being told I'm off though. I hear that I actually need to do:
    (4) ω = 2*∏*f
    (5) put in 400 for the f and calculate ω
    (6) do steps (2) and (3) as before
    Steps (4) to (6) make no sense to me though. If I do this, wouldn't it would make my signal take longer to attenuate?:confused:
  2. Jony130
    Feb 17, 2009
    3,991
    1,116
    The correct answer is step 4 to 6.
  3. Youssef.zein86
    Apr 24, 2013
    5
    Indeed the correct answer is step 4; however you should be logical in choosing the values of R and C.
    The salen key design assums that the imput resistance of the op-amp is infinity, so you have to choose R relatively small to the imput resistance of the op-amp.
    Typical voltage controlled op-amps have imput impedances that range 1 - 2 Mohms, so choosing R to be 50 times smaller will give good results, so R should not be higher of about 40 K, and you will find C as the last unknown of the equation.
