Need Help with counters!!!Please
Discussion in 'Homework Help' started by kjs_123, Oct 19, 2008.
  1. kjs_123
    Oct 16, 2008
    22
    How to Design two decade counters that are cascaded to produce an output from 00 to 99 on 8 digital outputs. Also to Arrange an input that can stop the count when brought low – use a switch on the development board for this purpose. Drive this design from your 1 Hz source.
    Any Suggestion would be helpfull....
    KJ
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Get a data sheet for a 74162 and look at the internal logic. Pretty simple.
  3. kjs_123
    Oct 16, 2008
    22
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Page 9 of the datasheet shows how to arrange a BCD counter. Just ignore the parallel load logic. Pay attention to how the logic stops the count at 9 rather than F.
    If you can't use a counter IC, then you can use standard logic to duplicate the function.
  5. kjs_123
    Oct 16, 2008
    22
    This is what I did in Quartus II....this BCD counter counts from 0-9 and then resets.....Please advice.....
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Then you need another one to count from 10 to 90.
  7. kjs_123
    Oct 16, 2008
    22
    You mean I will need to draw another one of them.....?
    How do I join them.....
    KJ
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The idea is that ANDing the outputs for '9' and the clock take the state back to 0. For the next stage, the previous state of '9' and a clock should advance the count.
