Need Help with Controlling Temperature
Discussion in 'The Projects Forum' started by gegofigo, Nov 17, 2007.
  1. gegofigo
    Nov 17, 2007
    thankes for all
    i want circuit about temperature control?
    can u:
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Welcome to the forum, gegofigo.
    I have moved your request for assistance with a temperature controlling circuit from the dormant thread to a thread of its own. In future, it is preferred that you establish your own thread rather than append it to an existing thread. This way confusion is avoided and you will receive help consistent with your own requirements.
    I recommend that you provide more specific details on your application for a temperature controller. The more information you give us the better we can help you.
    Enjoy you interaction with our member community.
    hgmjr
  3. Distort10n
    Dec 25, 2006
    429
    Check various temperature sensors from Texas Instruments TMP series, or ADI's TMP/ADT series.
    There are bound to be example circuits. In fact, look at the TMP122 from TI; it has an eval board that you can order.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Setpoint or proportional control? What is being controlled (source of the heat/cooling)?
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Infinity switch
    simple thermistor and opamp
    bimetallic switch
    expansion switch
    PID control
    manual
  6. gootee
    Apr 24, 2007
    447
    50
