I'm trying to identify a component which has no numbers or identifying marks. It's canary yellow and has 2 leads coming out of the bottom. The circuit board has the number "104" in the components location. there are 6 of these components on the board. They act like diodes as I use an analog ohm meter, they will pass voltage in one direction only. I've attached a pic with two of the components highlighted.
Thanks in advance for any help!
