Need help with choosig bench p/s
Discussion in 'General Electronics Chat' started by mikedavid00, Jul 21, 2012.
  1. mikedavid00
    Jul 16, 2012
    Im trying to get a small lab setup and would like a power solution to meet my needs for hobby use. Im not sure how many volt/amps I need. My main concern is as usuall i will have bought something that i'll find out is too weak to meet my needs and need to buy a whole new supply. Id prefer not to build my own. I also would like something cheap as i need to get a quality multi meter, osc and signal generator.
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    Your small lab, is this for hobby work at home, or a small lab at work, or are you planning on making this into a career?
  3. mikedavid00
    Jul 16, 2012
    Just hobby work for things like Guitar pedals and amps and speakers and such.
    I don't want to buy something that I'll have to replace later and definately dont want to build my own. I want to spend as a little as I can because I need to spend on a good volt meter and oscilloscope.
  4. MrChips
    Oct 2, 2009
    12,648
    3,458
    Then I don't see the need for a bench power supply.
    For experimenting with guitar FX circuits all you need is a 9V battery.
    If you are building guitar amplifiers, you will need a power supply for which I use a computer power adapter or wallwart, anything like 12V@5A, 15V@5A, 18V@3.5A etc. You can even find dual supplies +/- 15V.
    You can also turn a discarded computer power supply into a useful hobby supply. Cost you nothing.
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    Dual outputs, about 0- 20V each @ 3A would be minimum.
  6. TheLaw
    Member
    Sep 2, 2010
    228
    Ehh, if he wants a bench power supply, let 'em have one. I tried fuddling around with all sorts of adapters here and there and its just too much of a pain in my arse. If I want a circuit to work, I don't want to have to worry about silly power adapters.
    If you want to be cheap, though not necessarily "lab grade", you can go and get a cheap little +/- LM317/LM337 kit and then get a center tap transformer and call it a day.
    If you want to get more complicated, there's some more advanced circuits you can try yourself.
    I know you don't want to buy, but it's hard to find a reasonable quality supply for cheap. I might scrounge eBay for an old Power Designs or HP power supply. They are easily serviceable, good quality, and generally cheap.
