Need help with building electromagnet lift
Discussion in 'General Electronics Chat' started by Nagah, Apr 11, 2015.
  1. Nagah
    Apr 11, 2015
    5
  2. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    That is how a typical lift/material handling magnet appears, what is the resistance? Did you try it on an automotive battery or higher capacity?
    Typically when used as a lift magnet, it requires a reverse polarity shot also to demag.
    Max.
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    If it is of the PM/EM variety you will see (significant) 'force' only when the device is not energized...
    Best regards
    HP
  4. Nagah
    Apr 11, 2015
    5
    Does that mean, I charge the device for a long time before I can see the effect?
  5. paulktreg
    Jun 2, 2008
    625
    125
    What sort of battery are you using?
  6. Nagah
    Apr 11, 2015
    5
  7. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    ...Again What is the resistance of the magnet??
    Max.
  8. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    No... If it is indeed a PM/EM (i.e. permanent magnet/electromagnet) unit it will attract ferrous objects without power applied, whereas application of power (of correct polarity and current) will effectively 'cancel' its magnetic field. ----- On the other hand if the device is solely electromagnetic it will show only slight (residual) magnetism while non-energized, but become strongly magnetic with the application of power...
    To summarize:
    PM/EM: Power on => Magnetic field 'OFF'/ Power off => Magnetic field 'ON'
    EM only: Power on => Magnetic field 'ON' / Power off => Magnetic field 'OFF'
    BTW that's a very low capacity battery for your application!:eek:
    It may not supply sufficient current for even brief operation -- in any event it won't last long... As per posts Nos 2 and 7 you should ascertain the coil resistance such that you will be cognizant of the current/power requirement..
    Best regards
    HP
    PS: Please note that the eBay description of the magnet implies a current requirement of 250mA and, hence, a (nominal) resistance of 48 ohms...
  9. blocco a spirale
    Jun 18, 2008
    1,463
    371
    The solenoid requires 250mA @12V, you will not get anywhere near this current with that tiny 12V remote control battery.
    Hypatia's Protege likes this.
  10. Nagah
    Apr 11, 2015
    5
    Thanks so much. I will get a 12V battery with higher capacity and report back.
  11. MrChips
    Oct 2, 2009
    12,652
    3,461
    In order to lift a ferro-magnetic object the magnet must come in direct contact with the object. Only then will you experience the maximum lifting capacity.
  12. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    This is an example of the cranes I designed electronics for!
    As the magnet heats, the magnetic strength decreases.
    Max.
  13. Nagah
    Apr 11, 2015
    5
    Fabulous. This is the kind of thing my son wants to build for his science project. Do you have any tips on how to build a model version of this for his school project?
  14. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    A very simple relay for the pick up condition, you may need a short reverse demag pulse if light objects stay attracted at the point of turn off/drop.
    Max.
